Issue with RDM 2026.2.13.0 64-bit - https web pages won't open
Hi I would like to report issue with opening web pagers. I have many many connections saves as web browser to all our network devices and after last update web page with login prompt is blank. I'm getting standard untrusted certificate error and after pressing "continue" page is blank or not fully loaded. but from standard edge/chrome browser is fine
Thank you for reaching out about this matter.
I tested this using the latest version of RDM for Windows (2026.2.14.0) but was unable to reproduce the issue. Could you please confirm whether the issue persists with the latest version?
If the issue still occurs, could you please share screenshots of the affected entry's properties? In particular, screenshots of any menus or settings that differ from the default configuration would be very helpful. I will then try to reproduce the issue using the same settings.
I look forward to your reply.
Jacob Lafrenière
