Batch edit for user-specific settings
A fix for this issue has been implemented in version 2026.2.13.0
Implemented Backlog
We updated RDM from 2026.1.23.0 to 2026.2.11.0 and Devolutions Server to Version 2026.2.7.0. Since the update, the batch edit feature for user-specific settings no longer works properly. We use this feature to store our individual credentials from PAM or the User Vault (override credentials) for RDP session entries. For single entries, the credentials can still be successfully stored. When using batch edit, the credentials are successfully stored for one of the selected entries, but not for any of the other entries that were selected. Thank you for your support.
Kind regards, Simone
All Comments (4)
Thank you for reporting this issue. We will create a bug ticket for this and keep you updated on the progress.
Best Regards,
Michaël Beaudin
We've found and fixed the issue. You can expect this to take effect with the upcoming 2026.2.13 version.
Jafran Majeau
Hello Jafran,
Great, thank you! :)
Simone
I'm pleased to inform you that a new version of RDM (2026.2.13.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
