With the SSH session entries, we have the well-known PuTTY issue regarding numeric keypad not working in some applications such as nano, unless you disable the "keypad keyboard mode" in the "Terminal" tab of the entry's settings:
We regularly have this issue with new entries (as it default to a "Default" option which seems to imply "No"), and with the quick connect toolbar.
My question is: can we change the default value for this option? I believe the "Default" option is actually inheriting the settings from somewhere, but I cannot find where.
We are on a licensed RDM 2026.2 with a shared MSSQL Server database.
The default for this can be changed locally in File -> Settings -> Entry types -> Sessions -> Terminal
Best Regards,
Michaël Beaudin
