Beginner's Question for using scripts in endpoints
Product: PowerShell Universal
Version: 5.3.2
Hello everyone, I’m just beginning to understand how Powershell Universal works and I’m looking for an opportunity to ask “beginner” questions. I have created scripts under the automation section and am trying to use these scripts in endpoints. Unfortunately I get the message that these scripts cannot be found. what am I doing wrong or what have I overlooked?
Unfortunately, I couldn’t find anything in the documentation or intranet that could help me
Thank’s a lot
All Comments (19)
To use a script created in the Automation section in an Endpoint, you’d need to do something like:
<# PSU-Internal Account App Token #> $AppToken = '<redacted>'
Connect-PSUServer -AppToken $AppToken -ComputerName 'https://<redacted>'
Invoke-PSUScript -Script 'Folder\Script.ps1'
Edit: As parzog pointed out below, this seems to have a caveat of requiring your PSU installation to be licensed. If yours is licensed, my response is still valid; if it’s not, parzog’s response would be a better fit.
(anonymous user)
If the script you are writing will be ran deterministically within the endpoint, it may be better to define the script AS the endpoint. This would allow the execution to be triggered by the API call.
To hopefully explain a little bit more - when you are triggering an API call, with normal methods you typically need to authenticate yourself against the system. PSU handles this through app tokens. If your instance is unlicensed, you will not have access to App Tokens, and thus will be unable to proceed in the manner Jesse helpfully provided.
So, you likely will need to leave your endpoint unauthenticated. When the endpoint is not authenticated, it cannot trust that the call it received is authorized to execute the action. As a safety measure, the default setup restricts running those scripts from the system from within an unauthenticated session (such as a barebones API call).
This is very much watering down the specifics, but more has been explained in this forum in other recent places if you are willing to do a bit of reading. If you are licensed, however, then you can use App Tokens and specify your security model accordingly to allow execution of scripts within endpoints.
Hope that helps, and welcome to PSU (and the forums)!
I’ve never had an unlicensed instance of PSU, so I wasn’t aware of authentication being a paid-only feature. Good to know.
(anonymous user)
Yeah! For reference, to my knowledge the sections in the lighter grey (on dark mode) are paid:
Extrapolate this out to the other non-expanded columns as well. No app tokens = no auth!
Never noticed since it never applied to our setup.
Hello guys, thank you very much for the quick response. We have ordered a license but it still stuck within our ordering process, I’m currently experimenting without it. But thank you very much for your tips. My plan was to offer a series of scripts both via the GUI and via endpoints for automation solutions.
So if I understood it correctly then it obviously makes more sense to define the work in the endpoint and to call the endpoint in the script. Then I would have avoided the “permission” problem. Is that correct ?
Reverse that (you call a script from within an endpoint), assuming you’re saying that you want to go with the method I provided.
OK thanks - then I’ll wait for the license and try your suggestion
(anonymous user)
Welcome @andreasweber !
If you havent used it already, and you want to of course, you can get a trial license via Trial | PowerShell Universal - 14 days of unlocked - and be able to test
We did the same sort of testing your talking about here.
For our use cases we have scripts that are used by people via the portal and also used from automation/external events via an endpoint, the endpoint code gets the data that’s posted to it and extracts the parameters of the script to Invoke it, and people can run the same process - as well as us while testing/developing. Theres a bunch of ways to do it in PSU though
EDIT: Oo I could probably share a contrived example too, two secs
(anonymous user)
For cut down example - with no error checking, etc, etc we do something like this - and ill apologize for typos up front, its early where I am and just brain dumping
And you do want to be careful how long the script takes to run as per the best practices doc
From the external system
#$payloadJson contains json, $headers contains the apptoken
$payloadJson = "{IdentityId = `"Trigger`"}"
Invoke-RestMethod -Uri "https://psuniveralserver.local/api/disableperson" -Method POST -Body $payloadJson -Headers $headers
Endpoint
# log what we got in the body
Write-Information "Body: $($Body)"
# convert from json
$data = convertfrom-Json -InputObject $Body -Depth 5
#What params do I need for the function
$IdentityId = $data.IdentityId
$invokeParams = @{IdentityId=$IdentityId}
# This calls the script and waits for the result  - you can also add bits here to change what identity the script runs as - in this cae we just continuing with the endpoints auth via integrated
$scriptResponse = Invoke-PSUScript -Name "Identity\Disable-User.ps1" -Parameters $invokeParams -Integrated -Wait -TrustCertificate
#convert the object to JSON for rest consumption
$responseJson = "{Result = `"$($scriptResponse`"}"
return $responseJson
Script
param(
[Parameter(
    Mandatory = $true
[string]
$IdentityId = "DEFAULT/TESTVALUE"
# Using Write Information so it doesnt put this on the pipeline in the results, but will show in the script logs in the PSU server
Write-Information "Starting Disable of User"
## Do all the things with the param
$result = "WooHoo we are done!"
# This can return data objects so when run in PS, or in the portal/apps the results arent JSON encoded here
return $result
I received the license and implemented your suggestion for testing purposes – it works exactly as I hoped. Thank you for the detailed explanation.
(anonymous user)
I wonder if its possible to run a script with the api but have it be interactive ?
(anonymous user)
I’m not sure what this would look like - API’s are meant not to be interactive. What point at which would the interaction occur?
(anonymous user)
I would like to give some users the ability to open a PowerShell terminal, then “connect” to an “environment” and have a startup script with a Read-Host menu to choose which script to start and possibly provide more information using additional Read-Host prompts.
The script would run on PowerShell Universal (PSU), and the user would only select what to run in the environment. Basically, it would work like an app but using a PowerShell console - like a menu for scripts.
It’s easy to do locally, but if some scripts use a connection to Azure, it’s good to avoid installing the certificates on the computer of the user.
Note: “Connect” and “environment” can be replaced by any appropriate terms in PSU that would work. I just used them as general terms.
TLDR :
How it works:
  1. Users open a PowerShell terminal
  2. Users connect to a PowerShell Universal (PSU) environment
  3. A menu appears showing available scripts
  4. Users select scripts and provide any required inputs
  5. Scripts execute in the PSU environment, not locally
You could create a function using the Universal module to list out scripts in a menu. The user could then select the script and you could retrieve the parameters and provide a way to enter the values.
using namespace System.Management.Automation.Host
Import-Module Universal
function Enter-PSUServer {
    $AppToken = '<token>'
    Connect-PSUServer -ComputerName 'http://localhost:5000' -AppToken $AppToken
    $MenuItems = Get-PSUScript | ForEach-Object {
            Script   = $_
            MenuItem = [ChoiceDescription]::new("&$($_.Id) - $($_.Name)", $_.Description)
    $options = [ChoiceDescription[]]($MenuItems.MenuItem)
    $result = $host.ui.PromptForChoice("Select script", "Please select a script", $Options, 0)
    $selectedScript = $MenuItems[$result].Script
    $selectedScript.ScriptParameters
Enter-PSUServer
Select script
[1] 1 - s.ps1  [2] 2 - Script1.ps1  [3] 3 - Script2.ps1  [?] Help (default is "1"): 1
DisplayName                 : Parameter
Type                        : System.Object
ScriptId                    : 0
DefaultValue                :
Required                    : False
DisplayType                 : String
ValidValues                 :
HelpText                    :
ParameterSet                : Default
ResolvedDefaultValue        :
IValidateSetValuesGenerator :
Using                       :
Dynamic                     : False
You could also look into using terminals somehow.
docs.powershelluniversal.com
There are cmdlets for controlling those as well.
  • Start-PSUTerminalInstance
  • Invoke-PSUTerminalCommand
You’d want to be a little careful providing terminals like this since the users could potentially run whatever.
Adam Driscoll
Someday, I hope the PowerShell Team\Contributors implement custom remoting protocols.
github.com/PowerShell/PowerShell-RFC
Then we could just do:
$Session = New-PSUSession -ComputerName '' -AppToken
Enter-PSSession -Session $Session
And it would be like any other remoting session.
Adam Driscoll
