4.1.0 fresh install not working when using SQLITE
(anonymous user)
Out of the box installation of 4.1.0 yields the error below when trying to start.
Switching to “UniversalAutomation.LiteDBv5” i appsettings.json allows it to start.
Application: Universal.Server.exe
CoreCLR Version: 7.0.222.60605
.NET Version: 7.0.2
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentException: Format of the initialization string does not conform to specification starting at index 0.
   at System.Data.Common.DbConnectionOptions.GetKeyValuePair(String connectionString, Int32 currentPosition, StringBuilder buffer, Boolean useOdbcRules, String& keyname, String& keyvalue)
   at System.Data.Common.DbConnectionOptions.ParseInternal(Dictionary`2 parsetable, String connectionString, Boolean buildChain, Dictionary`2 synonyms, Boolean firstKey)
   at System.Data.Common.DbConnectionOptions..ctor(String connectionString, Dictionary`2 synonyms, Boolean useOdbcRules)
   at System.Data.Common.DbConnectionStringBuilder.set_ConnectionString(String value)
   at Microsoft.Data.Sqlite.SqliteConnectionStringBuilder..ctor(String connectionString)
   at Microsoft.EntityFrameworkCore.Sqlite.Storage.Internal.SqliteDatabaseCreator.Exists()
   at Microsoft.EntityFrameworkCore.Migrations.HistoryRepository.Exists()
   at Microsoft.EntityFrameworkCore.Migrations.Internal.Migrator.Migrate(String targetMigration)
   at Microsoft.EntityFrameworkCore.RelationalDatabaseFacadeExtensions.Migrate(DatabaseFacade databaseFacade)
   at PowerShellUniversal.SQLite.DatabaseFeature.InitializeDatabase(IConfiguration configuration) in C:\actions-runner\_work\universal\universal\src\PowerShellUniversal.SQLite\Plugin.cs:line 58
   at Universal.Server.Services.SystemPluginService..ctor(IConfiguration configuration) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\SystemPluginService.cs:line 78
   at Universal.Server.Startup.ConfigureServices(IServiceCollection services) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Startup.cs:line 59
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
   at System.Reflection.MethodInvoker.Invoke(Object obj, IntPtr* args, BindingFlags invokeAttr)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
   at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services, Object instance)
   at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass14_0.<UseStartup>b__0(HostBuilderContext context, IServiceCollection services)
   at Microsoft.Extensions.Hosting.HostBuilder.InitializeServiceProvider()
   at Microsoft.Extensions.Hosting.HostBuilder.Build()
   at Universal.Server.Program.<>c__DisplayClass3_0.<Main>b__0(Options o) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Program.cs:line 72
   at CommandLine.ParserResultExtensions.WithParsed[T](ParserResult`1 result, Action`1 action)
   at Universal.Server.Program.Main(String[] args) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Program.cs:line 52
All Comments (5)
(anonymous user)
@Adam Driscoll im getting similar on 4.1.1 (upgrade from 4.0.7) - when i change to litedb it works fine but not Azure SQL.
2023-09-19 09:16:31.878 +00:00 [FTL] Fatal error starting PowerShell Universal.
Microsoft.Data.SqlClient.SqlException (0x80131904): Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Operation cancelled by user.
The statement has been terminated.
—> System.ComponentModel.Win32Exception (258): The wait operation timed out.
at Microsoft.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at Microsoft.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction)
at Microsoft.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at Microsoft.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at Microsoft.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean isAsync, Int32 timeout, Boolean asyncWrite)
at Microsoft.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource1 completion, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry, String methodName) at Microsoft.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.EntityFrameworkCore.Storage.RelationalCommand.ExecuteNonQuery(RelationalCommandParameterObject parameterObject) at Microsoft.EntityFrameworkCore.Migrations.MigrationCommand.ExecuteNonQuery(IRelationalConnection connection, IReadOnlyDictionary2 parameterValues)
at Microsoft.EntityFrameworkCore.Migrations.Internal.MigrationCommandExecutor.ExecuteNonQuery(IEnumerable`1 migrationCommands, IRelationalConnection connection)
at PowerShellUniversal.SQL.DatabaseFeature.InitializeDatabase(IConfiguration configuration) in C:\actions-runner_work\universal\universal\src\PowerShellUniversal.SQL\Plugin.cs:line 66
at Universal.Server.Services.SystemPluginService…ctor(IConfiguration configuration) in C:\actions-runner_work\universal\universal\src\Universal.Server\Services\SystemPluginService.cs:line 78
at Universal.Server.Startup.ConfigureServices(IServiceCollection services) in C:\actions-runner_work\universal\universal\src\Universal.Server\Startup.cs:line 59
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass14_0.b__0(HostBuilderContext context, IServiceCollection services)
at Universal.Server.Program.<>c__DisplayClass3_0.b__0(Options o) in C:\actions-runner_work\universal\universal\src\Universal.Server\Program.cs:line 72
ClientConnectionId:055f9a8c-e290-48fa-9439-c58a298c42c1
Error Number:-2,State:0,Class:11
@AnonymousUser - This is due to the fact that our SQLite default connection string is not correct in the MSI. You’ll need to include data source: `Data Source=%ProgramData%\UniversalAutomation\database.db. This will be fixed in the next release.
@AnonymousUser - Was this a preexisting database? It’s failing to update the schema.
Adam Driscoll
(anonymous user)
Hi Adam, yes it is a pre existing db. I can delete it and start again if needed…
You shouldn’t have to drop the database. Are you using git sync and, if so, are you storing the repo in the database? we made a change in 3.9.17 that included a schema change to avoid an issue with large git bundles that might be causing this issue.
Adam Driscoll
(anonymous user)
I am using GIT but not through PSU. I had issues a while back (i know you have worked on this since) but I’m still on manual GIT sync with ADO. My Azure SQL db is 281MB.
Rolled back to 4.0.12 and it works fine.
