Does NOT remember password when running embedded?
It seems that at my computer, Remote Desktop Manager does NOT remember [password] and [domain] when I start a session in embedded mode. But it works fine if not in embedded mode.
My operating system is Vista SP1. Please help on this issue, thanks.
All Comments (1)
it's because the external use mstsc.exe (Microsoft Remote Desktop Client) to launch the connection and the password are set in the Windows Crendential Manager. The embedded view does use it, you have to set the password. Remote Desktop Manager Enterprise does not have this limitation but it's was not really as design. I could try to fix that, but that mean for me to hack the Windows Credential Manager to extract the password.
I'm sorry for this limitation, I will add a note for the future release.
Devolutions inc.
