Execute Typing Script After SSH Connection
A fix for this issue has been implemented in version 2026.1.23.0
Resolved
Hello, I have created a typing macro intended to auto-execute a few commands after logging in to my SSH sessions. I am editing the session, selecting Events, After opening, Select Execute macro/script/tool and choose the typing script I created.
When connecting to the host, I see in the lower right of the console it says 'Executing macro for 'my host name', but nothing is executing.
All Comments (10)
Hi Matthew,
Could you please let us know which version of RDM you are using, and what type of data source you are connected to?
Also, could you send us screenshots of how your SSH terminal entry is configured so we can try to replicate your setup on our side?
Finally, I’m sharing a private link where you can upload the video showing the complete behavior you described, including the moment where it says the macro is executing but nothing actually happens.
Alexis Geller Peiro
Hi there. I am running version 2026.1.20.0 64-bit (PreJIT). I am connecting to a linux based system over SSH. I have uploaded a video to that sharepoint link.
Hi Matthew,
Thank you for the update and for uploading the video.
We were able to reproduce the behavior on our side and found a bug where adding and selecting the Typing Macro entry the way you currently have it configured does not execute properly.
The solution would be to add a delay/wait time directly in the Typing Macro entry so that it runs a few seconds after the SSH Terminal session has opened.
As a workaround, we also found that you can add the same commands directly in the "After opening" tab, in the section at the bottom, instead of calling the Typing Macro entry. This should allow the commands to run after the SSH session opens.
Could you please test this and let us know if it works now?
Alexis Geller Peiro
I put in a 10 second delay for the macro/script, but still didn't work. It does work if I do it on an individual basis per your screenshot. I was just hoping to not have to do that since I have many of these types of systems that would need it.
With that said, I will add it though since I know it does work.
Thanks for your help.
