Using RDM to manage local Hyper-V on same computer
I have RDM set up to manage a remote hyper-v server with no issue. However, on the same machine that I have RDM, I run several hyper-v VMs.
I have tried 127.0.0.1 and local host and still get this:
Creds are correct but I am sure I am doing this wrong. Or maybe it's not possible. But I'd figure I'd post here to see if there might be some who knows how to do this right. (The same configuration for a workgroup hyper-v remote management is also in place on this machine)
All Comments (1)
I will first remove your previous post on the same subject to keep the discussion streamlined here.
At this time, I am not certain that this configuration is expected to work.
Could you please confirm the exact entry type you are trying to configure? Additionally, could you try using the full server name (even if it is the same host)? I would like to see whether this changes the error message.
I look forward to your reply.
Jacob Lafrenière
Closed
