RIght shift not working with VMware VMRC
A fix for this issue has been implemented in version 2026.1.19.0
Resolved
After the RDM update to 2026.1.18.0 with .NET 10.0.6 and using any VMRC remote connection entry in RDM, holding right shift does not uppercase any letters or numbers. Left shift works fine. Right shift works fine on any local apps or in any of my SSH terminals in RDM. It's only with VMRC. I'm using version 12.0.5-22744838 of VMRC.
All Comments (4)
Hi
We made some fixed in keyboard handling and it sounds like this regressed. I will take a look at that today and fix it ASAP.
Sorry for the inconvenience
Kind regards,
Richard Markievicz
Hello again
This should be fixed in 2026.1.19. Once it's available and you've updated, please don't hesitate to post back if you're still having problems.
Kind regards,
Richard Markievicz
I'm pleased to inform you that a new version of RDM (2026.1.19.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
Thank you! Works perfectly now.
