1 vote
Is there a way to pin the vault table to the side next to the "navigation" tab?
I created a vault for each client and would like to have all the different vaults visible on the side like the "navigation" tab.
Thanks
Hi Stefano,
Thank you for sharing your suggestion.
At the moment, this is not currently possible. I have moved your post to the Feature Request section so it can be taken into consideration for a future update.
We appreciate you taking the time to let us know what would be helpful for your workflow.
Alexis Geller Peiro
I believe this might already be possible. If you go in the "Window" tab, there's a button to open the "vaults pane". That pane can then be dragged and docked where you want:
Can you try this out and see if it works as you need?
Hi Hubert, it works fine
thank you!
Bye
Perfect, I'm glad to hear this works well for you. I'll mark this thread as resolved.
