Wrong Input when click f1-f12 button (ssh)
A fix for this issue has been implemented in version 2026.2.0.16
Implemented
I use ssh and open byobu.
All Comments (4)
I entered click f2 but instead the input was the character ~
Thank you for reporting this, we will investigate.
Nicolas Dufour
A keyboard setting must be configured to ensure that the function keys work properly when using Byobu. Currently, the mobile version does not support configuring keyboard options within the SSH Terminal entry. However, it will recognize and use the setting if it has already been configured.
To resolve this issue, set the Function Keys Mode to VT100+ in the keyboard options of the SSH Terminal entry. This setting cannot be configured on mobile platforms at this time. If you are using a non local data source such as Hub or Devolutions Server, you can configure it using one of our desktop versions, such as RDM Windows. Once configured, RDM Android will apply the setting, since non local data sources can be shared across multiple devices and platforms.
At this time, it is not possible to modify keyboard configuration options directly on RDM Android. A ticket has been created to add this capability in a future release, and we are aiming to include it in our June release.
Nicolas Dufour
I'm pleased to inform you that a new version of RDM Android (2026.2.0.16) has been released, featuring the fix for your issue.
Note that the version might not appear in the store directly. If it doesn't, it will be available in the next few days.
Maxim Robert
