Problem with multiple monitors
Hallo,
I have an issue regarding multiple monitors
My computer has 4 screens.
I create a remote desktop connection,
I set that it should use monitor 2 and 4.
When I open it, everything works properly.
Then if I collapse the remote desktop to icon and I maximize it again, it comes up on different monitors.
To make it work again I have to close the connection and open again.
Could you please help. It starts been quite annoying.
Thank you
Best regards
All Comments (1)
Thank you for reporting this issue.
I was able to reproduce the behavior on my end. At the moment, I’m not entirely certain whether this issue originates from Remote Desktop Manager or from the underlying RDP component itself.
That said, I have created a bug report for our development team so they can investigate further. I will get back to you as soon as I have more information or feedback from them.
Thank you for your patience, and please don’t hesitate to reach out if you have any additional details to share.
Carl Marien
