Backlog
sessions will not run
i have a number of PowerShell sessions created for mundane tasks, like unlocking a user acct. or running a sync cycle, and they all of a sudden stopped working. when i execute them they create the tab but no window will open and then after 10-15 seconds close. nothing happens, not errors, nothing in the debug...
Hello telwell1,
Thank you for reaching out to the Devolutions support team.
How do you run this script, and do you use the Devolutions cmdlet in it?
What I'm interesseted to know is:
  • Do you run this script inside or outside of RDM?
  • Do you use an powershell entry or the tool in the ribbon?
  • Do you execute this script from a file or embedded in the entry?
  • Are you launching the script as an admin or with a run as?
  • What was the version before the update?
  • If you use the Devolutions module, have you updated it?
  • Which data source type are you using?
Patrick Ouimet
i have tried the cmdlt too, same issues.
Do you run this script inside or outside of RDM? --- inside. they do work outside RDM.
Do you use an powershell entry or the tool in the ribbon? --- i have tried both.
Do you execute this script from a file or embedded in the entry? ---both, neither work.
Are you launching the script as an admin or with a run as? --- admin does not work, like its not using my Privileged acct. / and as run as admin, i have to enter admin creds every time. can that be change to remember creds?
What was the version before the update? - i rolled back from the latest to 2024.3031.0
If you use the Devolutions module, have you updated it? --- not using
Which data source type are you using? default connections. db
i am able to get some new connection i create to run, but they are asking for admin creds each time i run and not running tabbed,
Hello telwell1,
Thank you for this feedback.
I have sent you a direct message to schedule a session with me.
Patrick Ouimet
