Problem with upgrade from 80>82
Yesterday I upgraded from 8.4.x to 8.9.12 and the database was upgraded succesfully.
Now I installed 8.9.13 and RDM 8.9.13 is asking for a DB upgrade from 80 > 82.
I am logged into RDM with my admin account but this is the message I receive:
http://screencast.com/t/5jRCpOwcPKBr
http://screencast.com/t/L0Q2qlonX
What going wrong?
Cheers!
Sjoerd
All Comments (4)
The upgrade is trying to enable "nested triggers", it looks like you don't have sp_configure privileges.
EXEC sp_configure 'nested triggers', 1;
Try running the upgrade with a user that has the privilege (sa or other).
I will look at maybe implementing the feature with a different method (without recursion).
http://technet.microsoft.com/en-us/library/ms188787.aspx
Permissions
Execute permissions on sp_configure with no parameters or with only the first parameter are granted to all users by default. To execute sp_configure with both parameters to change a configuration option or to run the RECONFIGURE statement, you must be granted the ALTER SETTINGS server-level permission. The ALTER SETTINGS permission is implicitly held by the sysadmin and serveradmin fixed server roles.
Stéfane Lavergne
Stefane,
Is this something new from version .13?
I have not had any upgrade problems before.
Cheers!
Sjoerd
Yes, the bug was introduced in the .13 will be fixed in the .14
Stéfane Lavergne
Instead of asking for sp_configure permissions we changed our implementation to work regardless if 'nested triggers' is enable or not.
Stéfane Lavergne
