Resolved
activate connection with Enter key
1 vote
Small issue. Before I updated to Remote Desktop Manager 2026.1, when I typed a server name into the search box, it would highlight the first matching entry and then I could hit enter to make it connect. Now, hitting enter does nothing and I have to use the mouse to go up and double-click on the entry to connect. Muscle-memory, quickness, and easy of use would be served by adding that capability back.
Recommended Answer
This was reported by other users and it wasn't an intended change. We've made a fix that should be available starting with our next minor update, 2026.1.11.0. We are hoping to release it as soon as we can.
All Comments (1)
