Installation problem with .NET 10.0.0 which is required for RDM 2026 release
I've been using this software for years and love it.
With the recent March 2026 update, I have been required to install the Microsoft Windows Desktop Runtime version 10.
In my instance, it is the version 10.0.3 (x64).
However, the setup failed. I got the "error 0x80070006 The handle is invalid."
There is a log file (snippet below) from the installer.
I did restart computer and got same error.
Until I get this installed, I can't run RDM.... :-(
Does anyone have some ideas to solve this?
Thanks
Michael Zwarg
[8470:93A8][2026-03-03T11:29:47]i010: Launching elevated engine process.
[8470:93A8][2026-03-03T11:29:49]i011: Launched elevated engine process.
[8470:93A8][2026-03-03T11:29:49]e000: Error 0x80070006: Failed to wait for child to connect to pipe.
[8470:93A8][2026-03-03T11:29:49]e000: Error 0x80070006: Failed to connect to elevated child process.
[8470:93A8][2026-03-03T11:29:49]e000: Error 0x80070006: Failed to actually elevate.
[8470:93A8][2026-03-03T11:29:49]e000: Error 0x80070006: Failed to elevate.
[8470:8528][2026-03-03T11:29:49]i000: Setting string variable 'WixStdBARestartRequired' to value ''
[8470:93A8][2026-03-03T11:29:49]i399: Apply complete, result: 0x80070006, restart: None, ba requested restart: No
Hi
I haven't seen that before, but it seems like the installer bootstrapper is having hard time elevating permissions (it's a per-machine install).
At a guess of something easy to try: can you launching the installer from an elevated context? i.e. Try right-click "run as administrator".
Thanks and kind regards,
Richard Markievicz
I solved it by uninstalling RDM ver 2026. Then installed .NET runtime v 10.0.2, installed .NET runtime v10.0.3, then reinstalled RDM v2026.x
Hello
I'm glad you got it working. For the record I don't think uninstalling RDM should have changed something; but it's hard to say - Windows Installer is a very old technology and sometimes you get strange issues like this. The .NET installer is especially complex, because the .exe is actually a bootstrapper for 4 separate .msi installers.
Please, don't hesitate to post back if you have further questions or comments
Richard Markievicz
