Hello all. I'm fairly new to RDM and I have a question about using SSH keys with the built in ssh shell. Is there a way to have an ssh key in the credential list and use it on ALL of the ssh shell connections? I know I can do each separate session but I'm wondering if I can do it globally. Is there an add on that I could use? I like using the builtin because it's faster for me since it shell not have to run a separate application, like putty.
I would be interested in knowing if it's possible.
Thanks!
Glen
maybe you can do if you save your ssh-key in .ppk-file and add in advanced-register change app to Plink and under "other parameters" insert cmd-line-parameter with .ppk?
Kind Regards
Markus
We've been planning to create a credential entry of sub-type "private key"
You could use it as any other credential entry
Its on our board, we just need the time to implement it
Maurice
Well great! Thanks for the info. I want it now but I guess that will have to do. :-)
