Is there a way to be able to select, say, a folder of devices and run the Macro 'typing' tool in bulk without all the sessions being open. I am using this in a school environment so typically an account may be logged into the computer at the time, or it needs to be applied to a class of devices, so impractical to login remotely to all of them. I have the Agent installed on a test device but I couldn't get it to run the Macro typing script I set up (very basic, just the start key for now!).
Thank you.
I'm afraid that to execute a Script or macro using the Devolutions Agent, you would need to have a connection opened to the remote machines.
If you would like I can move your topic to the feature request section.
Samuel Dery
