Double click point to jump
1 vote
Hi all,
I'd like a very simple feature. When you double click on an entry using a jump host to connect, RDM points to the entry of the jump in the tree navigation pane. This is very annoying, every time you need to point manually again to the entry on which you need to connect, especially when authentication fails or you need to do a change.
It should be better if the selection remained on the entry you want to connect to.
Regards.
All Comments (1)
I assume the following option should work in this case. Although I don’t currently have a Jump Host to test it, I’m confident it will function as expected.
Let us know!
Min
