I've tried creating a Smart Folder using controller as the search name but it doesn't show anything in the folder.
If I then put controller in as a filter it shows all the connections that have controller in the name which is what I would expect to see in the smart folder.
Anyone got any ideas why this isn't working and is there any way of converting a filter to a smart folder?
Thanks
Jon
The smart folder isn't intended to work in the treeview, it works in the dashboard where it will list the entries it finds. For instance, here I added "team" to the entry name parameter.
Best Regards,
Michaël Beaudin
