Load plug-ins in embedded mode
Hi
I have an issue with this feature on x64 bit OS.
The plugin we are using is Thinprint and here is a installer for 64bit os http://thinprint.dkvistun.is/9/TPCLWin3290x64.zip
now i add a registry key for it to work with C:\windows\syswow64\mstsc.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Terminal Server Client\default\AddIns\ThinPrint
New string Value : Name
Value : C:\Windows\System32\TPClnRDP.dll
Now if i use mstsc 32bit and mstsc 64bit Thinprint gets loaded but is does not get loaded in embedded mode in RDM
Valdi Hafdal
All Comments (4)
We will investigate.
Just to make sure
Works:
embedded mode with RDM - 32-bit
external mode with RDM - 32-bit
external mode with RDM - 64-bit
Does not work:
embedded mode with RDM - 64-bit
Stéfane Lavergne
You need to use the v9.0 beta with the 64 bit version of RDM
Where can i download RDM 9 x64 BETA ?
Both x86 & x64 are available within the beta download (zip/msi)
Look for RemoteDesktopManager64.exe (no shortcut is created yet)
http://download.devolutions.net/Devolutions.RemoteDesktopManager.Bin.8.9.9.0.zip
Stéfane Lavergne
