whats the syntax in the session entry to create a local port forwarding?
What I need is
L3391 -> 127.0.0.1:3389
thx
I need to open top after the session is opened, otherwise the server will disconnect me after a few minutes.
Didnt get that to work with the embedded ssh host.
You need to configure a putty session for that.
damn.
Can I execute a command with the embedded ssh tunnel after login?
Embedded ssh tunnel works great, but I need to open top or something or I´ll get kicked.
Have you verified the after login command?
