Greeting everyone. I run into a problem using RDM.
I've downloaded and installed the latest version, as well as the latest version of dotnet. However, when I start RDM, a message appears that I should install or update dotnet at least 9.0.
I am using x64 win 11 24H2 new and powerful machine.
Please advise.
Regards, Max
Hi Max,
Thanks for the details. Since RDM is still prompting you for .NET 9, it might help to reinstall the runtime directly from the official source, just to rule out any installation issues.
You can find our requirements and manual deployment notes here:
https://docs.devolutions.net/rdm/overview/system-requirements/#manual-portable-deployment
And you can download .NET 9 from Microsoft here:
https://dotnet.microsoft.com/en-us/download/dotnet/9.0
If you can, try reinstalling the .NET 9 runtime from that link and then launch RDM again.
Let us know how it goes and we’ll dig deeper if needed.
Alexis
Alexis Geller Peiro
