Web entry - extentions
1 vote
Is it or could it be possible to get extensions working with web entries.
Or a way to get dark mode on web entries!
I appreciate this is unlikely possible but just asking in case it is.
Thanks
Iain
Version 2026.2.13.0 64-bit
Data Source SQL
All Comments (1)
Hello Iain,
I've moved your thread to the feature request forum, as this is not currently possible. For the theme, it seems there's a property to the Webview2 control (which we use), so it's probably an easy change. I will open a ticket for this so we can make the themeing of the Webview2 controls match the current theme of RDM.
For the extensions, we will have to investigate. There might be ways to do this but they don't seem simple and I'm not sure they would work with every extension Edge supports. I will open a separate ticket for this.
