I can't find any clear guidance to create/apply users to our license from inside RDM.
I can get to the user management dialog but the options aren't clear.
Can you advise what steps I need to follow to add my users?
(see attached pic)
Thanks,
Michael
To add a little more context:
I have created an Entra group.
This group has db_datareader/db_datawriter to the database.
I add entra users to that group.
MFA is already configured for our organisation.
I just need to know how to create and assign the users to the license stored in the datasource.
Thanks.
The assignation of the RDM licenses is managed via the Licenses button under the Administration menu.
See https://docs.devolutions.net/rdm/commands/administration/licenses for more information.
I've assigned the license, that isn't the issue.
I need to know how to assign USERS.
There is zero guidance on the devolutions site for this.
I think I understand what you are trying to achieve.
Are you trying to manage the access to the database using Entra groups so that adding users to those groups will grant them access to the database?
If yes, it's not possible to manage users and permissions using Entra groups with the usage of a SQL Azure database.
You need to create your users manually and then provide them the proper permissions.
The documentation regarding this could be found below:
https://docs.devolutions.net/rdm/commands/administration/user-management/user-types/
https://docs.devolutions.net/rdm/user-groups-based-access-control/
If your goal is to manage access to RDM via groups to simply the onboarding and/or the access management, this is possible, but you would need to use Devolutions Server as your backend datasource. Here's the homepage of that https://devolutions.net/server/ . We have documentation regarding the installation (https://docs.devolutions.net/server/getting-started/) if you would like to do it by yourself or we can also propose your a remote session with a member of the support team.
