Zoom setting per session?
Is there a setting somewhere that allows for text/zoom level per session? Specifically, right now I am opening a simple Powershell embedded session. But every time I open it I have to ctrl mouse wheel to make the text smaller. Not a huge deal, but would be nice if I didnt have to.
All Comments (1)
It is possible to change the font and size of the text.
To do so, please go to your entry's properties -> Terminal -> Display. Then, change the font to "Overpass" and adjust the size as needed.
Carl Marien
