SFTP Do Same for All Existing Overwrite/Skip Fails to Do Same
A fix for this issue has been implemented in version 2025.3.22.0
Transferred a folder across sftp within an ssh. I was on a PC and ssh'd into the linux machine, copying from Linux to PC. Whole folder with a bunch of existing items and it did not "accept" the check box to do the same skip/overwrite.
2025.3.15.0 64-bit (PreJIT). I know x.16.0 is available, but in the middle of something.
All Comments (5)
Thanks for pointing this out!
I was able to reproduce the same behavior on my side.
Just to confirm — you’re referring to the checkbox “Do this for all conflicts”, which, even when checked, still prompts you to select Overwrite or Skip, correct?
Stephan
Correct. I did not have the screen up to get exact wording. After having to click on about 300 files I did not feel like trying again!
Thank you for the confirmation.
We’ve opened a development task to address this issue.
Stephan
A fix for this issue will be included in version 2025.3.22.0.
Jonathan Del Signore
I'm pleased to inform you that a new version of RDM (2025.3.22.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
