2025.3.6.7 crashes when trying to create a Connection String entry
Backlog
Have just updated to 2025.3.6.7. Database also updated. Trying to create a Connection String entry crashes RDM. I can create a Username and password entry fine. Can create Connection String entry on Windows version ARM64 2025.3.15, same datasource.
Using Azure SQL Server as datasource.
/Anders
All Comments (2)
Hi Anders,
I was able to reproduce the issue. We’ll fix it and include the correction in an upcoming release.
Jesse Galarneau
Hi Jesse,
Thank you for confirming this issue.
