Offline mode not responding
I'm using RDM version 8.9.2.0
When I connect in online mode to the SQL server database, I have no problems.
When I connect in offline mode, regularly the program suddenly freezes (not responding) and after 30 seconds, I get the popup again of "Do you want to connect in offline mode?". Also in some cases, all my sessions in the navigation pane are gone (If I just restart RDM, all sessions are back though).
I've changed the data source connection timeout to 10 seconds, and then, when the program freezes, it takes 10 seconds to get the popug again.
All Comments (2)
I think I've found the issue.
I have an RDP session in tabbed mode open. Within that session, I press F5 to refresh the eventviewer log for instance.
It seams that RDM also picks up the F5, and tries to connect to the online datasource.
The full message I got after pressing F5 within the RDP session from RDM was: "Unable to connect to the data source. Do you want to go in offline mode?"
Could you try to disable the shortcut mapping by clicking on the little magnet in the statusbar? Does it help?
