Certificate issue with RDM 2025.3 beta
A fix for this issue has been implemented in version 2025.3.12.0
Resolved Implemented
Just tested the new beta version of RDM (2025.3.10.0). While RDM tries to connect to our Devolutions Server, we receive the following error message. RDM 2025.2 versions work fine.
All Comments (8)
Thank you for reaching out!
My name is William, and I'm here to assist you in any way I can.
This error is related to the certificate attached to your Devolutions Server. It looks like RDM sees that the URL used by the Devolutions Server doesn’t match the certificate’s CN/SAN issuer. Could you confirm that the URL used by the Devolutions Server matches the Hostname listed in the certificate?
@William Alphonso
Hi William
Yes, I can confirm that the URL used for our Devolutions Server matches the hostname within the certificate. The Edge Browser or any other browser does not complain about the certificate not being valid.
It's a certificate of our internal Certification authority, the root Certificate is available on the machine.
And as I told, all 2025.2 version do not show any error.
Best regards
