Opening Document using the "View" button, sets write protected flag
Backlog
I've recently noticed that documents became randomly write protected.
Until I saw that RDM is setting the write protected flag, as I have a document linked inside RDM for easy access.
Something that also seems weird is that if I add that document again but with "read-only" set in the properties of the entry, it also opens the document in read-only but without setting the flag.
Now my question is, why is it that when I have the document added normally and open it with "view" it sets a write-protect flag on the file and also doesn't set that back after opening the file unless I open it as a session where it does set that back.
Is this potentially a bug?
Since it seems like there's no need to set a write-protect flag on the file itself in order to open it in read-only when it seemingly is able to open a file in read-only mode without setting the flag.
It is definitely a bit annoying, I'd really appreciate it, if it would be possible to change the behaviour in a future update so it doesn't set read-only on the file or at least give an explanation on why it was made to behave that way.
Could you please specify the version of RDM you are currently using?
What type of data source are you using?
https://docs.devolutions.net/rdm/data-sources/data-sources-types/
Are you using the "Document" type entry, or are you using the "Attachments" section of an existing entry?
Let me know,
Samuel Dery
Let me know,
@Samuel Dery
I'm using version 2025.2.29.0 with the XML data source.
It's about a document type entry.
Thanks for the quick response.
Thank you for the follow-up.
I was able to reproduce the issue you are experiencing with the read-only tag. I will report this bug to the development team, and they will begin working on a fix soon.
I will follow up with you as soon as a fix is deployed in a future update.
Jacob Lafrenière
