Recommended Answer
Thank you for the confirmation. Since it is only one entry that is having the issue, I would recommend using the Entry History in RDM to restore the entry to before it broke.
Then compare the information between the versions of the entry and select the last version that wasn't broken:
Feel free to reach out if you have any questions or need further clarification.
