View Lost Between Sessions
If you select tree view, close the program, and reopen you are back to a list view.
Seems like it should remember that you had the tree view turned on and keep it that way when you close / reopen.
Thanks,
Dustin
All Comments (1)
It's saved by default, but I think that your setting is lost. Do you use a roaming profile ?
