RDM will not launch after update (.NET issue)
I finally updated my copy of RDM to the latest version and now it won't launch. I get no splash screen. Looking at past similar issue posts, I checked the event viewer and see what looks like a .NET related issue:
Faulting application name: RemoteDesktopManager.exe, version: 2025.2.25.0, time stamp: 0x68760000
Faulting module name: coreclr.dll, version: 9.0.825.36511, time stamp: 0x68768e66
Exception code: 0xc0000602
Fault offset: 0x00000000003254aa
Faulting process id: 0xc60
Faulting application start time: 0x01dc0b72e503cca5
Faulting application path: C:\Program Files\Devolutions\Remote Desktop Manager\RemoteDesktopManager.exe
Faulting module path: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.8\coreclr.dll
Report Id: c8eb48e9-cc92-4ba9-9f12-768c41d3af62
Faulting package full name:
Faulting package-relative application ID:
However I have tried uninstalling, reinstalling, and repairing the .net 9.0.8 install including deleting the entire C:\Program Files\...\9.0.8 folder prior to reinstall and I'm still facing the same error. I actually initially updated to 2025.1.41 because one of our databases has a version restriction and I didn't want to update it, but had the same issue so now tried 2025.2.25 as a hail mary and that didn't help.
I see, could you follow the steps in this knowledge base article and let me know if this helps?
https://docs.devolutions.net/rdm/kb/troubleshooting-articles/net-corrupted-system-file/
Samuel Dery
Hi Samuel,
Unfortunately I ran both of these and am still encountering the same error.
For what it's worth, I am running Windows 11 Pro Version 10.0.22000 Build 22000
Hello
I'm afraid your Windows version is too old. As far as I can tell, 22000 corresponds to 21H2, where .NET 9 is supported on 23H2 or newer for Pro systems.
While it's true that .NET 9 will install and run on older systems; it by default enables new security features that are only compatible with the newer OS versions.
I realize our minimum requirements page is confusing. We do include the link to the .NET 9 requirements, but the core requirements still list 21H2 as the minimum Windows version. I'm going to contact the documentation team to get that fixed.
Please, let me know if you have any questions or something is not clear.
Kind regards,
Richard Markievicz
Closed
