Auto resize window or focus on bottom left? Using Remote Desktop Manager - RDP session to Windows Servers.
Resolved
Apologies if there is already a feature for this but when I am using RDM and open enough windows servers that starts a new row, the vertical resolution is cut off, so each server I switch to, I have to use the scroll bars to scroll down and to the left in order to get to the start menu. Right clicking and reconnecting will rescale but it seems a like there could be a better way.
Im thinking a few different options would help here...
  1. Have a setting that auto scales the screen to whatever size the window is inside RDM. This could be auto sensing when it changes.
  2. Allow the user to set the location.... Default the window to bottom left (or wherever user selects) when switching to a tab or server. Access to the start menu is what I am after without scrolling.
Thanks in advance.
All Comments (2)
Thanks in advance.
@kennethg0523
I found the setting customizing the RDP app in RDM to change the scaling. It was not easy to find but is there, so thank you again in advance.
Hello kennethg0523,
Thank you for this feedback.
Happy to know you have resolved this.
Do not hesitate if ever you have any other questions.
Patrick Ouimet
Ends in 5 days
