Hello Everyone,
i have a strange behaviour going on for some weeks or even months.
I am connecting to a certain host using RDM running on my Mac. The connection lags, drawing is slow.
Then i am connecting to my virtual desktop from my Mac but using Microsoft Remote Desktop (Windows App). This virtual desktop runs Windows 11 and has RDM on it too. It is sitting on the same network as the target host.
When i then connect to the same target host as i tried from my Mac, the connection is just fine and faster than connecting from my Mac directly.
How is that even possible?
Hello
That does sound strange. There are a lot of things that can affect RDP performance but the answer is not clear based on what we know.
Can you clarify the setup?
RDM -> Windows Host (slow, laggy)
Windows App -> Virtual Desktop (RDM Windows) > Windows Host (good performance)
Where both Windows Host and Virtual Desktop are on the same network.
Is that correct?
Are you able to repeat the second case using RDM instead of Windows App (i.e. connect to the virtual desktop as a jump host), or is it not possible? (this might be the case depending on the authentication setup).
Can you reproduce the problematic case with session logging enabled, and then send the log file to me either by PM or to service@devolutions.net (mentioning this forum thread). It will show the codecs being used and etc, and might give an important clue.
Please let me know if something isn't clear.
Thanks and kind regards,
Richard Markievicz
Hello again
Also - I forgot to ask - what's the server OS and version on the problematic host?
Kind regards,
Richard Markievicz
Your assumptions are correct, yes.
I have simply duplicated the entry for the problematic host in RDM and changed the IP to my desktop and... its still faster using this and then going to the host inside the desktop.
Sent you a PM with the logs
Hello again
Thanks for sending the information through. There are differences in the connection sequence between the two hosts. What is the server OS and version of the problematic host?
How is performance if you connect to the problematic host directly using Windows App?
Richard Markievicz
Its a Server 2019 Build 1809.
Yes, connecting directly through Windows App works better.
Hello
A couple of things spring to mind; perhaps it can be an issue with some redirection or otherwise a poorly chosen codec.
For the codec, I'll have to check on my side what gets negotiated with FreeRDP and that version of Windows.
Can you try to disable all the redirections in the "Local Resources" tab and let me know if something is different? Remote Audio = "leave on the remote computer", Remote Audio Recording = "do not record" and disable all the checkboxes in "Local Devices and Resources".
Richard Markievicz
Hi Richard,
Ive always redirecting clipboard only and nothing else.
Best Regards
Daniel
Hello
The Windows Server and the Windows 11 host are both on the same network as I understand it; but does your client exist on a different network? Are you connecting over the LAN or WAN?
Richard Markievicz
Hello
I have the same issue. I’ve been a long-time RDM user, but recently I noticed that RDP performance is extremely sluggish on my MacBook running macOS Sequoia 15.6 with RDM version 6.2.1. I don’t know exactly when it started, but today I began troubleshooting it.
This is not a network problem, because the issue does not occur in other clients (Microsoft Remote Desktop app for macOS, Royal TSX). I also tested the same servers in Windows using the native RDP client, and everything works fine there as well.
The problem seems to affect some servers, but I couldn’t find a clear pattern of why exactly RDM lags while other clients perform normally.
Hi @baxenko
Thanks for your post; the comparison with RoyalTSX is really interesting because we both use the same RDP backend (FreeRDP), so this is a true apple-to-apples comparison (comparing with Windows App is always tricky since it's something of a black box to us).
Is it the case that it's always the same sessions that are laggy? Or - within the same session, one day it's laggy and one day it's fine?
Richard Markievicz
Hi @baxenko
As I said earlier, I did not find any dependencies. I can say that the problem is definitely observed on some servers that use RD Gateway without dependencies on time and sessions, while on servers with direct RDP access, the problem has not been noticed.
When connecting to the server, the response is normal for the first 5 seconds or so, but after 5 seconds, the delay begins to be noticeable.
There are no problems with these same servers in RDM on Windows.
The problem was noticed about a month ago.
Hello
That's interesting. Can you enable session logs like in this KB article, and once you get the problem send me the corresponding log? You can disable the logging again afterwards (it degrades performance).
Richard Markievicz
Hello
@Richard Markiewicz sent logs to service@devolutions.net
