It appears that in the latest version - 2025.2.14.0. Within the Vault -> Properties -> Both the Save and open / Save buttons perform the same action. Both buttons Save & open a connection.
Thank you.
Jason -
Hello Jason,
Which data source are you using? Since I cannot reproduce the behavior on my end with version 2025.2.16.0, could you please try using this version?
https://devolutions.net/remote-desktop-manager/home/download
Min
Hello Min,
Yes. The 2025.2.16.0 version seems to have resolved this issue. Thank you for your support.
Kind Regards,
Jason -
