FileZilla Import Add-in problems
Hi!
2 small issues:
I installed the FileZilla from Add-on-Manager and RDM crashed without any stack trace (Remote desktop manager Stopped working). After reopening it everything worked though.
Then I tried importing my FileZilla sessions, which also worked, but it did not import saved passwords. Is this expected?
Thanks!
Daniel
All Comments (6)
I remember when we did the filezilla import, at that time the password was stored in clear text in the Filezilla xml. Could you verify if this has changed?
Turns out I derped. I never has passwords saved in my FileZilla
All fine, Thanks :)
It's changed. I have FileZilla version 3.17.0.1 and passwords are not in clear text.
They are:
<Pass encoding="base64"></Pass>
Thank you for notifying us! Could you check out the latest version of the add-on 2.3.0.0 http://remotedesktopmanager.com/Home/AddOn#ImportAddOn_FilezillaImport This should fix the issue with the import of the password.
I confirm that version 2.3.0.0 solves this issue.
Thank you.
Closed
