Five seconds delay when switching tabs using KiTTY
I'm using KiTTY in portable mode instead of PuTTY (has some nice extra features including automatic reconnect). When I have a KiTTY tab open to a server that does not respond (the server is off for instance) switching between tabs in Remote Desktop Manager takes five seconds or so. This does not happen with PuTTY.
It only happens when Connection > Attempt to reconnect on connection failure is activated
Where do you see the Attempt to reconnect on connection faillure? Could you post a print screen?
"Attempt" to reconnect is nothing you can see (actually you can see KiTTY's title changing). It's an option within KiTTY.
PuTTY on the other side will try to connect once and then on failure do nothing until you manually reconnect
