I've got about 100+ sessions with SCRT in various folders that I'm trying to import, using the addon.
Choosing 'Local Session', the session window just comes up blank
Choosing 'Shared Session', it just constantly comes up with 'no entry found in file'. Tried using
C:\users\username\appdata\Roaming\Vandyke\
and
C:\users\username\appdata\Roaming\Vandyke\config
and even
C:\users\username\appdata\Roaming\Vandyke\Sessions
NOTHING is being detected here. Something is definitely wrong with the importer
Using
SCRT: 7.1
Windows: 8
I will ask André to help you. He did the importer. He will contact you to ask your some questions for sure.
A fix is in the Beta version for that issue.
The "Edit" fonction wont work in the "Import Sessions" dialog but you will be able to import your sessions.
André Sanscartier
And how do we get access to the beta version? I don't see any way on your site.
I kind of need this working here, I can't manually import all of these. I expected it would be working, already!
This was a small issue in the version 8.2. It's fixed in the hot fixed version:
http://remotedesktopmanager.com/Home/ThankYou?f=RDMsetupBeta
I see what you meant. I apologize, thought you were referring to a test version of the importer, not the program itself.
All seems to be well and good now, thank you :)
No problem, you're right, our post was confusing
