Connecting to a Bomgar box
In a future release is there a possiblity that you might figure out a way to connect this up to a bomgar box?
All Comments (8)
Do you know if a command line tool is available for bomgar box? Does it install something on your machine ?
it installs a client on your local machine which connects up to the box, then you get your list of machines that have the client running on their machines.
Do you have some documentation about this client application, for example the command line ?
C:\Program Files (x86)\Bomgar\Representative\remote.nextechsupport.com\bomgar-rep.exe
That is the command line for the exe of the client. The client pops up with a request for a username and password. To open the client.
If needed I could let you on my machine if you wanted to look at it real quick
Do you know if you can pass parameters to the command line ? I will keep your name for when I'm ready to develop the addon.
This forum will go public in a week or so I think.
Could ask here: http://community.bomgar.com/
We use this unit, it's pretty expensive but awesome :)
//Brandur
Thank you for the tips. I will see what I can do.
