RDM doesn't work with UltraVNC and DSM Plugins
I'm using RDM version 5.6.3.0 and trying to use the Quick connect feature with VNC at the top of the main window. I cannot connect to any machines with VNC because we use DSM plugins for encryption. It seems like there is nowhere to configure the ultravnc tool for quick connect. The command line is "vncviewer.exe -dsmplugin PluginName.dsm"
Is there a registry key I can change to update the vncviewer configuration.
All Comments (5)
It's not possible, but I entered a feature request to pass other param to the command
Devolutions inc.
I don't remember if it was available in the version 5.6, but the version 5.7 contains a field to add other parameters to the command line. Maybe you can try to -dsmplugin PluginName.dsm to this field.
This is not available when you open VNC embedded.
Devolutions inc.
You can do that if you're creating connections to be saved. I am just trying to use the Quick Connect feature because I could need to connect to any one of 250 desktops using UltraVNC. Adding and managing connections for that many desktops that change fairly regularly would be v time consuming. Perhaps when you are specifying the path to the UltraVNC in the settings you could also specify parameters that could apply to all connections whether saved or quick connect.
I see, but you can create a template and use it in the Quick connect. The template can be created with the menu File->Templates.
Can you give it a try and let me know.
Devolutions inc.
That works great! Thanks for your help.
