I have been using RDM for some years now without issue.
I have moved laptop which has force reinstall export/import of RDM vault etc.
Basic windows RDP is working as normal.
My problem is that for some use cases I need to execute PowerShell beforehand to establish an AWS SSM Tunnel to the instance before I connect.
I would achieve this by adding a before event to run a PowerShell script, wait 25 seconds for the tunnel to establish and then continue to connect RDP.
This continues to work in my existing setup but no longer works in the new.
Thanks in advance,
Michael Dawson
The error:
When I launch the session I receive an error:
After allowing UAC elevation I then get the following error in a PowerShell window:
The session attempts to immediately connect (no delay settings in the event dialog on new version??) and fails.
I layout a comparison of settings below fyi…
Failing version
Working version
Hello michaeldawson,
Thank you for reaching out to the Devolutions support team.
Since you have opened a case and a forum, let's investigate through the case and I'll post the result here.
Patrick Ouimet
