Why does sort order differ between Private Vault and other vaults?
All our shared vaults I use use our local collation where ÅÄÖ comes at the end of the alphabet but my private vault use some other collation where ÅÄÖ is sorted like AAO. Why does it differ and is it configurable somewhere?
Recommended Answer
Are you using sort priority? Setting it to -1 I can get it to display at the bottom.
Without sort priority all looks good in both shared & user vaults.
Stéfane Lavergne
Could you post a screenshot to explain exactly where you observe the different sort order? Is it in the tree view? It should not differ, but I need some clues to investigate.
Yes, it is the tree view that differ.
First is our shared vaults where the collation matches what I expect, (ÅÄ)Ö is sorted after XYZ
Here is my private vault where (ÅÄ)Ö is sorted as AAO.
Stéfane Lavergne
Yes, there was Sort priority set for the shared vault. That explains the behavior, thank you!
