SSH connection on 2025.2.13.1 64-bit (JIT) keeps dropping after update
I updated to the latest version (2025.2.13.1 64-bit (JIT)) on June 8 and ever since SSH connections have been dropping after 30 minutes idle time. I have set each SSH connection to "Enable TCP keep-alives" enabled and ping interval to 5 seconds. Despite setting these SSH session keep dropping and it's only been happening after new update. Please advice. Thank you.
All Comments (4)
It appears the ping is broken in this version. I am going to work on fix right now.
Just to be sure, your ping settings are the same as before the update?
Denis Vincent
Yes, I didn't change it after the update. Thank you.
Also the vi editor and vim editor are so slow in this update. for example, when I try to move cursor from left to right, it gets stuck and had to close and re-open several times to get to the right text.
Thank you.
Any update on this? Or how long do you think it will take to get this fixed? Please advice. Thank you.
Denis has made a fix internally and it will be available in our next minor update of RDM. We are expecting to make this update next week if all goes well.
