Sub entry collapse issues
1 vote
Not sure if I am missing something. However we have an ssh session and 3 child sub ssh sessions. If you double click anywhere on the parent name to open it in the navigation with tree view it collapsed the sub sessions. So you can no longer see the sub sessions. We would like a way to shut that off.
Maybe there is a better way to have a parent ssh session with 3 child?
Or maybe there is a way we can indent the sub sessions without making them child session, we mainly use this to see they belong to that session but dont need the inherent or anything?
Or just fixing it or having an option to shut it off so you have to click on the arrow to do so would be nice.
I've opened a ticket for this. I feel like by default, it shouldn't collapse when expanding. It might be a side-effect of being handled similarly to folders, where double clicking them expands/collapses them.
We've changed how the default handling of the tree view works. Double clicking on a parent entry (that isn't a folder) will no longer collapse or expand its content. This should provide the behavior you are looking for. This should take effect with the upcoming 2025.2.14 version.
Jafran Majeau
@Jafran Majeau
Thanks!
