Hi Hubert,
When I try to modify an entry and try to modify the hostname for $NAME$.domain. Local, I got that error.
I am using 2025.2.7 with Devolutions Hub Personnal.
at Devolutions.Hub.Clients.HubClient.PutEntryAsync(Guid vaultId, Guid entryId, Entry entryToPut, CancellationToken cancellationToken) at Devolutions.Hub.Clients.HubClient.<>c__DisplayClass78_0.<<PutEntry>b__0>d.MoveNext() --- End of stack trace from previous location --- at Devolutions.Hub.Clients.HubClient.PutEntry(Guid vaultId, Guid entryId, Entry entryToPut) at Devolutions.RemoteDesktopManager.Managers.DevolutionsHubDataSourceManager.SaveConnectionAsEntry(Guid dataSourceID, Guid repositoryID, Connection toSave, Connection[] currentConnections) at Devolutions.RemoteDesktopManager.Managers.DevolutionsHubDataSourceManager.SaveConnection(Guid dataSourceID, Guid repositoryID, Connection toSave, Boolean forceNoGetCurrentConnections) at Devolutions.RemoteDesktopManager.Business.DataSources.HubConnectionDataSource.SaveConnection(ConnectionEngine engine, Connection connection) https://forum-api.devolutions.net/api/messages/208218/attachments/4ba5eef3-854e-4d57-b7f7-6429a22a5a61.png
Hello Sebastien,
I've moved your post to a different thread to make this investigation easier.
I've contacted our Hub team to check with them what the issue might be, we'll get back to you soon.
Hello Sebastien,
Could you answer a couple of questions to help us understand the source of the issue?
Thank you, have a good day!
Maxime Morin
