Import Sessions from DameWare Mini Remote Control v6.8 to Remote Desktop manager 5.6.3
I would like to take the C:\Users\"username"\AppData\Roaming\DameWare Development\MRC.dbf
file and import it into Remote Desktop manager. I know that you can open and convert a dbf file into excel, sql, or HTML. Is there a simple way to do this oe do you have plans to add this to your import menu?
Thanks Sean
I added that to my todo list. Can you send me a fake (no real data) dbf file ?
Devolutions inc.
I used a dbf viewer to see the database in excel. I then saved it as this file. I can also send you the dbf file if you need.
Thanks
I will need the dbf file directly to really integrate the import.
Devolutions inc.
