Drag & Drop copy of subitems in navigation panel not working
I'm using Version 2025.1.37.0 64-bit of the Remote Desktop Manager. Since some previous versions the drag & drop copy of subitems in the navigation panel isn't working anymore. First level items got no problems with that. If you click on a subitem, dragging it with pressed STRG, there is a "+" icon on the mouse cursor, but the item just get moved not copied. As fas as I know that worked correctly in previous versions some time ago.
All Comments (2)
Thank you for bringing this to our attention.
I was able to reproduce the behavior you're describing with the drag & drop copy of sub entries in the navigation panel.
I've created a development task to investigate this further, and I'll make sure to keep you updated as soon as we have more information.
Stephan
We've made some improvements to the copy through drag and drop, specifically so that these interactions can be used with sub-entries. These should be available with the upcoming 2025.2.10.
Let us know if these work the way you expect them to.
Jafran Majeau
