Exclude feature from vertical and other views except cascade
1 vote
I would like to be able to setup in session settings for say a website and when I click on vertical or 2x2 they don't show up in it.
i would also like a manage option for sessions so you can toggle them on and off like you can from manage broadcast. So you don't have to move them in with another session to have less in view.
All Comments (4)
Could you give us more information as to how you currently work and what you'd like to achieve? We already have a feature for tab groups which help organise entries when opened so they are filtered by their tab group. I feel like using this with the view settings might be close to what you'd like to achieve.
Yes I use those but when you tile 2x2 or side by side. It does not only make tiles for the current tab but for the all tab. And anything not in the current tab show as a blank tile.
So say I have 6 sessions. 4 in tab 1 and 2 in tab2. And I'm in tab one and do side by side I get 6 tiles and 2 show as blank. I would like it to only show 4 tiles that are in the current tab.
It would also be nice to also be able to be able to toggle them as viewable in the tiles or not from a menu incase your done using one. But just fixing to only tile from the current tab would be awesome.
Thank you for the additional information. I've also tested with tab groups and you're right, it doesn't act how you'd expect. I've opened a ticket to improve the behavior of the feature with tab groups. For now I think that's what makes more sense rather than adding a new configuration to change the behavior.
Thanks!
